Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the DTD Wizard > How the DTD Wizard Creates XML Integration ObjectsIntegration objects consist of elements, attributes, PCDATA, names, hierarchy, connectors, and cardinality. CAUTION: The DTD Wizard will take out the recursion by breaking loops. Entities in XML at run time are not supported. |
XML Reference: Siebel eBusiness Application Integration Volume V |
