XML Reference: Siebel eBusiness Application Integration Volume V > Introduction >
Additional Resources
The product documentation set for Siebel eBusiness Applications is provided on the Siebel Bookshelf or in Online Help. The following integration-related books and online help explain all the tools required to implement integration:
  • Siebel Tools Online Help if you plan on using COM, CORBA, or the ActiveX Plug-ins to accomplish integration and also as a reference for Siebel business objects and components.
  • Siebel Business Process Designer Administration Guide.
  • Siebel Enterprise Integration Manager Administration Guide if you will perform bulk loading or unloading of data.
  • Application Services Interface Reference.
The Connector books provide specifics on each of the associated connectors.
