Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Deleting Data > Editing the Configuration File for Delete Processing > Deleting All Data RowsIf you want to delete all data rows in a target base table, you must perform the following procedure. Typically, this would only be performed in a test environment. To delete all rows in a target base table
CAUTION: Use the DELETE ALL ROWS = TRUE setting with extreme caution. It will indeed delete all rows in the target base table. |
Siebel Enterprise Integration Manager Administration Guide |
