Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Deleting Data > Editing the Configuration File for Delete Processing > Deleting Data Rows Identified by User Key ValuesYou must complete the following procedure to delete rows identified by user key values. To delete rows with user key values appearing in the EIM tables
NOTE: Although you can use the DELETE EXACT parameter to delete rows from both target and nontarget base table, you should only use it to delete nontarget base tables that contain user keys. Rows in nontarget base tables that do not contain user keys will not be deleted. Rows from the following tables do not have primary user keys and thus cannot be deleted using this parameter: |
Siebel Enterprise Integration Manager Administration Guide |
