Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports >
Importing Contacts
This topic provides information organized as follows:
For more information related to the importing of contacts, see:
ASGN_* Flags
When you import contacts and set positions using EIM, the flags ASGN_MANL_FLG, ASGN_DNRM_FLG, and ASGN_SYS_FLG are set so that the intersection records are not routed to remote users. The Contacts view on the local database will display fewer contacts than the same view for the same user on the server database.
S_POSTN_CON.ROW_STATUS Flag
The column S_POSTN_CON.ROW_STATUS is a flag that can have value Y or N. When a contact is imported with value Y for this column, the contact shows in the user interface with an asterisk [*] in the New column, which means it is a new contact.
