Siebel Enterprise Integration Manager Administration Guide > EIM Performance Tuning > Troubleshooting EIM Performance > Dropping Indexes in Initial RunsTypically, the EIM initial load is a very database-intensive process. Each row that is inserted into the base table requires modifications on the data page and the index pages of all the affected indexes. However, most of these indexes are never used during an EIM run. Index maintenance is a very time-consuming process for most database managers and should be avoided as much as possible. Therefore, the goal is to determine any indexes that are unnecessary for EIM and that can be dropped for the durations of the EIM run. You can create these indexes later in batch mode by using parallel execution strategies available for the respective database platform. Using this approach can save a significant amount of time. NOTE: Under normal operations, using parallel execution strategies is not recommended.
NOTE: Testing should always be performed when dropping indexes (or adding indexes) to make sure that expected results are achieved. |
| Siebel Enterprise Integration Manager Administration Guide |
