Siebel Enterprise Integration Manager Administration Guide > EIM Performance Tuning > Troubleshooting EIM Performance > Creating Proper Statistics on EIM TablesUse of the .IFB file parameter UPDATE STATISTICS is only applicable to the DB2 database platform. This parameter can control whether EIM dynamically updates the statistics of EIM tables. The default setting is TRUE. This parameter can be used to create a set of statistics on the EIM tables that you can save and then reapply to subsequent runs. After you have determined this optimal set of statistics, you can turn off the UPDATE STATISTICS parameter in the .IFB file ( To determine the optimal set of statistics, you need to run several test batches and RUNSTATS commands with different options to see what produces the best results. Before and after each test, you should execute
The file EIM_CONTACT1_mim.sql contains SQL UPDATE statements to update database system catalog tables with the saved statistics. You can experiment with running test EIM batches after inserting the RUNSTATS commands provided in DB2 Version 6/7 Options and DB2 Version 8 Options. After you find the set of statistics that works best, you can apply that particular mim.sql file to the database. NOTE: Do not forget to save statistics with DB2 Version 6/7 OptionsThe following RUNSTATS commands can be used with DB2 versions 6 and 7:
db2 runstats on table SIEBELDB.EIM_CONTACT1 with distribution and indexes all shrlevel change
DB2 Version 8 OptionsThe syntax for DB2 V8 commands provides more options, as follows: The clauses |
| Siebel Enterprise Integration Manager Administration Guide |
