Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table and Column Mappings > Viewing EIM Table Mappings to Base TablesUse Siebel Tools to view EIM table mappings to base tables. To view EIM table mappings to base tables
You can view mappings for all interface columns, but you can only add or modify mappings for extended columns in the base schema to extended columns in the EIM tables. Figure 2 shows an example of viewing the EIM table mappings for the EIM_ACCOUNT interface table. In the EIM Table Mappings list applet, you can find information about each base table that has been mapped to the selected EIM table. The Destination Table field contains the physical name of the mapped base table. You can also see which temporary columns (T_*) EIM is using when processing a mapped base table. |
Siebel Enterprise Integration Manager Administration Guide |
