Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table Columns > Mandatory Columns for EIM ProcessingROW_ID. For an EIM table row to be eligible for processing, you must initialize its ROW_ID. The ROW_ID, in combination with the value of IF_ROW_BATCH_NUM, must yield a unique value. The ROW_ID values in the EIM tables are not the ROW_ID values that are assigned to the row when it is loaded into the base table. An EIM-generated ROW_ID has a ##-###-### format. A regular row ID that is assigned to the row has a #-## format. IF_ROW_BATCH_NUM. You must set the values in this column to the same integer, greater than or equal to 0, as an identifying number for all rows to be processed as a batch. The maximum value is 2147483647. Use this column as the first key of any new indexes created on an EIM table. IF_ROW_MERGE_ID. You can set this column to one of two values:
IF_ROW_STAT. EIM updates this column after processing the row to indicate the status of the record. The IF_ROW_STAT column is not used by EIM when determining which rows to process. When populating the EIM tables, you can set this column to any value except NULL. You can initially set this value to FOR_IMPORT to indicate that the row has not been imported. After processing, if certain rows were not imported due to a data error, you should change: If EIM updates this column to NOT_ALLOWED after processing a row, EIM has attempted to insert a new row but the action is not allowed. In such cases, the INSERT ROWS parameter may have been set to FALSE. IF_ROW_STAT_NUM. After processing, this column contains a zero (0) if a row was successfully processed to completion. If processing failed, this column contains the pass number where the pass failed. Temporary columns. EIM uses temporary columns to manipulate data during processing. For example, EIM might store the ROW_ID value for a Siebel base table in a temporary column. These column names begin with T_ and indicate the table or column for which they are used. Because EIM uses these columns internally during processing, do not manipulate these columns in the EIM tables. For detailed information about each EIM table, generate a table mapping report. See Generating EIM Table Mapping Reports. |
Siebel Enterprise Integration Manager Administration Guide |
