Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table Columns >
File Attachment Columns
Three EIM table columns must be populated in order to import file attachments. Table 3 describes these columns and uses the attachment file budget99.doc as an example.
Table 3. File Attachment Columns
FILE_NAME |
This column requires the root filename of the file attachment. |
FILE_NAME="budget99" |
FILE_EXT |
This column requires the extension type of the file attachment (DOC, XLS, or TXT). |
FILE_EXT="doc" |
FILE_SRC_TYPE |
This column requires the value "FILE" or the rows cannot be imported. |
FILE_SRC_TYPE="FILE" |
You can also use these columns to define hyperlinks, as shown in Table 4.
Table 4. Defining Hyperlinks With File Attachment Columns
FILE_NAME |
Set to actual URL |
FILE_EXT |
NULL |
FILE_SRC_TYPE |
'URL' |
