Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > Other Examples > Example of Setting Explicit Primary MappingsAfter importing a Contact using EIM_CONTACT, you can use EIM_CONTACT3 to import the Contact's personal email addresses into S_PER_COMM_ADDR. You can explicitly set the primary email address by populating the primary flag column CON_PR_EMAIL_ADDR with Y. Table 2 shows an example of setting the primary email address for Contact "CON100" to "John.Smith@hotmail.com." If an explicit primary mapping is not used or not used properly—such as no address or more than one address flagged as the primary email address—then EIM ignores this explicit primary mapping and sets the primary implicitly. |
Siebel Enterprise Integration Manager Administration Guide |
