Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > Other Examples >
Example of Improving Performance by Dropping Indexes
Often, especially for initial EIM loads, you can improve EIM performance by determining that there are indexes present which are not being used for a particular EIM process. By pinpointing the unnecessary indexes, and by dropping them for the duration of an EIM run, you can achieve performance improvements. For an example of this, see Dropping Indexes in Initial Runs.
