Siebel Field Service Guide > Agreements > Process of Setting Up Agreements > Configuring Data Maps to Copy Specified ItemsField Service provides conditional data mapping capabilities which can be used to specify that only certain information be copied to the agreement. To accomplish this, you can add a source search specification to the data map. The ISS Copy business service then copies a source expression to a destination field. To add a search specification to a data map
Example: Copying Service Products from Orders to AgreementsThe following example uses a search specification to specify that only service products should be copied from an order to an agreement. To copy only service products from orders to agreements
Example: User ScenarioFrom the order, the user creates assets, using asset-based ordering to do so. When you have asset-based ordering turned on in Siebel Order Management, end users can use the Accounts screen > Installed Assets view to create orders based on a customer's existing assets. Installed assets can include both products and services. When these views are used with the automated asset-based order workflows, the amount of time to create quotes, orders, and agreements covering those asset records is reduced because many tasks are automated. The user covers the assets with the service product on the order and clicks Auto Contract on the Service Order screen > List > Agreements view. The agreement is created with only the service product for the agreement line item and the assets added as covered assets. Product line items that are not service items are not added to the service agreement. |
| Siebel Field Service Guide |
