Siebel Field Service Guide > Agreements > Agreements Screen >
Agreements List View
The Agreements List view displays all agreements that are visible to the user. Table 46 describes some items in Agreements records.
Table 46. Selected Items in the All Agreements View
Item
Description
Currency
Code for the type of currency; for example, USD for U.S. dollars.
For agreement-based invoicing, this value is used as the target, or overriding, currency. Before performing invoice calculations, all the input currency values, such as the ones in the NPR Plan and the Usage Plan, are converted to the target currency. Calculations are then performed in the target currency. After the calculations are completed, these values are written back as Invoices, Invoice Line Items, and Invoice Line Item Details, all in the target currency.
Effective
Actual date the agreement is effective. Can be later than, earlier than, or the same as the Start date.
End
Date the agreement will end.
Start
Date the agreement is planned to start.
Valid
Indicates the agreement is valid. Must be selected for consideration of the entitlements when verifying coverage with Verify Button. Also, preventive maintenance actions for assets are only initiated if this box is selected and the selected entitlement is active, based on its start and end dates.
