Siebel Field Service Guide > Cycle Counting and Replenishment > Products Screen > Service Details ViewThe Service Details view provides the information used in locating and allocating products. The Allocate Below Safety, Auto Allocate, and Auto Substitute check boxes in this view do not apply to cycle counting or replenishment. This view has two subviews, Inventory Options and Substitutes. Inventory Options SubviewThe Inventory Options subview sets the inventory locations for a product and determines the cycle counting parameters for each product at a specific location. The Allocate Below Safety, Auto Allocate, and Auto Substitute fields in this view do not apply to cycle counting or replenishment. Table 102 describes items in Inventory Options records. NOTE: A product can receive any combination of class ABC and XYZ; for example, AY. However, cycle counting must be based on either ABC or XYZ, not both. Substitutes SubviewThe Substitutes subview specifies the products that the Fulfillment Engine may use to fill an order when the specified product is unavailable from inventory. The user chooses from products that are specified in the Products view. For more information, see Products View. NOTE: Substitutions are unidirectional. Product A may substitute for product B, but B cannot substitute for A unless that substitution is explicitly defined. |
| Siebel Field Service Guide |
