Table 97.	Parameters for the Cycle Counting Engine
    Mode  |
    SQL  |
    Specify the WHERE clause to set up criteria and count the parts which meet that criteria.  |
    Id  |
    Specify the ID of the inventory location or the inventory type and only the parts related to that loc/type will be counted.  |
    TempTbl  |
    Put all the required parameters into a temporary table with a temporary Client Request ID and pass that ID to the server to retrieve the parameters from Temp Table.  |
    ClientId  |
    A row ID for retrieving params from the temp table  |
    Required when Mode = TempTbl.  |
    RowID  |
    Row ID of an Inventory location or Inventory type  |
    Required when Mode = ID.  |
    StartDT  |
    Start Date  |
    Required. The proposed start date of cycle counting.  |
    EndDT  |
    End Date  |
    Required. The proposed end date of cycle counting.  |
    Where  |
    Where Clause  |
    Business Component Search Spec mode. Required when Mode = SQL.  |
    Loc/Type  |
    Inventory Location or Inventory Type  |
    Required when Mode = ID or TempTbl.  |
