Siebel Field Service Guide > Fulfillment >
Fulfilling Orders
Follow these procedures to fulfill service orders, which includes identifying and reserving items specified in an order. To allocate parts for a service or internal order manually
- Navigate to the Service Order screen > List > view.
- Drill down on a selected order record.
- Click the Line Items view tab, and then select the line item to allocate.
- On the link bar, click Actions.
- Create a new record and complete the fields as appropriate.
NOTE: If the Logistics Manager and its Fulfillment Engine are installed, the Fulfillment Engine automatically specifies Allocate actions.
To generate a pick ticket for an order
- Navigate to the Service Order screen > List view.
- Drill down on a selected order and click the More Info tab.
- Click the menu button and choose Generate Pick Tickets.
To locate order line items
- Navigate to the Service Order screen List view.
- Drill down on a selected order and click the Line Items tab.
- Select a line item, scroll down and click the Part Locator tab.
- In the Line Items list, click one of the following buttons:
- Locate - Searches for the product through inventory locations, and then loads the list of available and substitute parts in the Part Locator subview.
- Locate All - Finds inventory locations for all line items.
NOTE: Before clicking either of these buttons, make sure that the Service Product flag on the Administration - Product screen > More Info view is cleared. If this flag is not cleared, the Parts Locator engine will not find any products.
To allocate order line items using the Part Locator
- Follow the procedure To locate order line items.
- In the Part Locator view, select a product/inventory location record in the Available Substitute subview or the Line Allocation subview.
- In the Qty field, enter the number of items to allocate. If no quantity is specified, the total available quantity is allocated.
- If the selected record is in the Available Substitute list, click the appropriate button:
- Allocate All. Allocates available parts automatically, starting with the first listed inventory location, up to the value in the Qty field.
- Allocate. Allocates the selected line item from a selected product/inventory location record.
To fulfill orders using the Fulfillment Engine
- Select an order and from the menu drop-down list, choose Fulfill.
To fulfill order line items
- Drill down on a selected order and click the Line Items view tab.
- Select an order line item, and then do one of the following:
- From the menu drop-down list, choose Fulfill to fulfill the selected order line item.
- Click Fulfill All to fulfill all order line items.
To de-allocate order line items
- Navigate to the Service Order screen.
- Drill down on a selected order, and click the Line Items view tab.
- Select an order line item.
- Select the action item (of type Allocate) to de-allocate. Then from the menu drop-down list, choose De-Allocate.
