Table 71. Parameters for the Fulfillment and Part Locator Engines
SysPref_DefaultFulfillInvloc |
SFO |
Specifies the default inventory location to use as a source inventory location for the Fulfillment Engine and Part Locator. This is used as the Source Inventory Location if the user does not specify the Source Inventory Location at run time. The value must be the Row ID of the service inventory location. To find this ID, use the following procedure:
- In any Service Inventory view, select an inventory location.
- From the Help menu, select About Record.
- In the dialog box, click Details.
SysPref_InventoryTypeForPT |
Warehouse |
Specifies the Inventory location type from which pick tickets are generated. The values should be from the Inventory location type LOV and individual values should be any of the LIVs. |
SysPref_AllocationRule |
1 |
Specifies the rules for substitution. The possible values are 1,2,3 where:
- Always allocate a substitute before going to the next inventory location.
- Allocate a substitute only if it allows shipment from a single inventory location.
- Never allocate a substitute if the exact product can be found in another inventory location.
SysPref_Fulfill-SearchAllSublevels |
TRUE |
Specifies whether to search child locations. Possible values are TRUE and FALSE. TRUE - Search the specified inventory location and all its child inventory locations specified by Sublevel relationships. FALSE - Search the specified inventory location and all its fulfillment hierarchy locations, but not the child inventory locations specified by Sublevel relationships. |
SysPref_OrderTypeToBeFulfilled |
Service Order, Internal Order, RMA Advance Exchange |
Specifies the valid values for Order Type. The values should be from the Order Type LOV and individual values can be any of the LIVs. |
SysPref_OrderStatusToBeFulfilled |
Open, New, Pending |
Specifies the valid values for Order Status. The values should be from the Order Status LOV and individual values can be any of the LIVs. |
SysPref_OrderItemStatusToBeFulfilled |
Specifies the valid values for Order Item Status. The values are from the Order Item Status LOV and the individual values are LIVs. |
