Siebel Field Service Guide > Charges and Invoices > Charges and Invoices Screens > Activities ScreenThe Activities screen has four views that are related to invoices. Time Tracker ViewThe Time Tracker view lists the labor charges associated with an activity. The Start and Stop buttons in the Time Tracker view provide convenient recording of time spent on an activity. Table 58 describes items in the Time Tracker view. Auto Time Sheet (selected from the application-level Tools menu) produces new records in the Expense Tracker view. For more information about setting up and using Auto Time Sheet, also known as Auto Gen, see the chapters on time reporting and expense reporting in Siebel Professional Services Automation Guide. Expense Tracker ViewThe Expense Tracker view records the expenses associated with an activity. Setting the Billable flag for an expense record makes this information available to the charge consolidation business service. By default, this flag is set if the Billable flag is set for the activity. Auto Expense Report (selected from the application-level Tools menu) produces new records in the Expense Tracker view. For more information about setting up and using Auto Expense Report, also known as Auto Gen, see the chapter on expense reporting in Siebel Professional Services Automation Guide. Part Tracker ViewThe Part Tracker view records products or assets used in the field for an activity. If the Billable flag is set in a record, the charge consolidation business service includes this part in an invoice. By default, this flag is set if the Billable flag is set for the activity. Invoices ViewThe Invoices view displays all invoices associated with an activity. Table 59 describes items in the Invoices view. |
| Siebel Field Service Guide |
