Table 63. Selected Items in the Charge Plan Subview
Adjust Charge |
Positive or negative adjustment to the amount of a charge. The Charge Engine clears this field after generating a charge. |
Commit |
When selected, activates the Charge button. |
Charge Basis |
Method of charging. Make a choice from the drop-down list:
- Advance. Advance charges are generated one period in advance.
- Schedule. Generates the charge according to the Contract Schedule.
Charge End |
Last possible date to generate a charge. |
Non-Recurring |
Total amount of the nonrecurring charge of which payments will be spread out per the NRC schedule. The nonrecurring charge can include a service charge or a discount. NOTE: If an NRC plan is not specified, the default behavior is to divide the NRC amount by the NRC Qty and generate the resulting amount each period.
NRC Plan |
Predefined NRC billing plan, chosen from a dialog box. If this field is blank, the NRC amount is divided equally among the total payment installments shown in NRC Qty. |
NRC Qty |
Number of installments for paying the nonrecurring charge. |
NRC Schedule |
Defines how frequently and when the charges are generated. The NRC schedule can be different than the invoice schedule. |
NRC Start |
The start date for nonrecurring charges. |
RC Adjust |
Amount to charge for partial periods as defined in RC Schedule. For example, if charges are generated monthly, this field defines the dollars per unit of time that the Charge Engine uses to calculate the RC charge line item. |
RC Adjust U/M |
The length of time for which the adjustment amount applies. |
RC Schedule |
Defines how frequently and when the charges are generated. NOTE: If a product measurement record is defined for this line item (product), the RC Schedule frequency must match the Frequency value in the Administration - Products screen > Service Information > Measurements view.
RC Start |
Recurring charges are only created after this date. |
Recurring |
Amount of a recurring charge. |
Use Plan |
Predefined use plan, chosen from a dialog box that displays only the plans that apply to the product in the selected line item. |
Use Start |
The start date for usage charges. |
