Table 122. Preventive Maintenance Engine Parameters
Mode |
{SQL, Id, TempTbl} |
This required parameter specifies how the engine locates the entities to process. Only SQL or ID should be specified in user requests. TempTbl is used by the client applications for submitting requests. |
Sub-mode |
{Assets, Plans, Assets&Plans, Agreements} |
This required parameter identifies which entities are specified. A Sub-mode of Assets implies ALL PM Plans, and a Sub-mode of Plans implies ALL Assets. |
End Date |
YYYY-MM-DD format |
This required parameter specifies the date furthest into the future for which the engine will generate PM Actions. Note that currently, only time-based triggers can fire for a future date. |
Asset ID |
Row ID of an asset |
This parameter specifies a specific asset. It is required when the Mode is Id and the Sub-mode is either Assets or Assets&Plans. |
Plan ID |
Row ID of a PM Plan |
This parameter specifies a specific PM Plan. It is required when the Mode is Id and the Sub-mode is either Plans or Assets&Plans. |
Agreement ID |
Row ID of an agreement |
This parameter specifies a specific Agreement. It is required when the Mode is Id and the Sub-mode is Agreements. |
Asset SQL |
Where clause for the GET_SQL_ASSETS template. The where clause takes the following form: [BusComp Field Name] = 'Value' |
This parameter specifies a search specification for assets. It is required when the Mode is SQL and the Sub-mode is either Assets or Assets&Plans. The SQL template for retrieving assets is as follows: GET_SQL_ASSETS = SELECT asset.ROW_ID FROM &Table_Owner.S_ASSET asset WHERE $SEARCH_SPEC$ The value supplied as the Asset SQL parameter is substituted for '$SEARCH_SPEC$.' Thus, any specification that completes this template with valid values is allowed for the parameter. |
Plan SQL |
Where clause for the GET_SQL_PM_PLANS template. The where clause takes the following form: [BusComp Field Name] = 'Value' |
This parameter specifies a search specification for PM plans. It is required when the Mode is SQL and the Sub-mode is either Plans or Assets&Plans. The SQL template for retrieving PM Plans is as follows: GET_SQL_PM_PLANS = SELECT pln.ROW_ID FROM &Table_Owner.S_PM_PLNITM pln WHERE pln.ACTIVE_FLG = 'Y' AND $SEARCH_SPEC$ The value supplied as the Plan SQL parameter is substituted for '$SEARCH_SPEC$.' Thus, any specification that completes this template with valid values is allowed for the parameter. |
Agreement SQL |
Where clause for the GET_SQL_AGREEMENT_IDS template. The where clause takes the following form: [BusComp Field Name] = 'Value' |
This parameter specifies a search specification for agreements. It is required when the Mode is SQL and the Sub-mode is Agreements. The SQL template for retrieving PM Agreements is as follows: GET_SQL_AGREEMENT_IDS = SELECT agrmnt.ROW_ID FROM &Table_Owner.S_DOC_AGREE agrmt WHERE agrmnt.VALID_FLG = 'Y' AND $SEARCH_SPEC$ The value supplied as the Agreement SQL parameter is substituted for '$SEARCH_SPEC$.' Thus, any specification that completes this template with valid values is allowed for the parameter. |
