Siebel Field Service Guide > Preventive Maintenance > Assets Screen > Plans SubviewThe Plans subview associates PM plans with selected assets. When you select the Active check box in this view, the Preventive Maintenance Engine can process this plan. You can clear this check box while defining a plan or to disable specific plans temporarily. When the plan definition is complete or a plan is reinstated, select this check box. NOTE: Selecting the All Assets check box in the Products view associates all assets of a product line with a selected PM plan. If the asset is not already associated with a PM plan (the All Assets check box is cleared for the product), users can cover the asset by adding the PM plan as a record in this subview. For more information, see Products View. |
| Siebel Field Service Guide |
