Siebel Field Service Guide > Setting Up and Using Scheduling > Optimizing Schedules (End User) > Stopping the Optimization of a Service RegionThis task is a step of Process of Scheduling Activities. Perform the following procedure to stop an ongoing optimization of a selected service region. Stopping an optimization may not be immediate because the Optimizer completes the solution that is in process and saves this solution in the database. NOTE: Stopping an optimization is a manual process; the Workflow Manager or repeat component jobs cannot send this command. |
| Siebel Field Service Guide |
