Table 118. Selected Items on the Warranties View
Expenses |
Indicates that this warranty covers the cost of expenses incurred by field service agents. |
Labor |
Indicates that this warranty covers the cost of labor. |
Parts |
Indicates that this warranty covers the cost of replacement parts. |
Start Date Type |
Specifies which field value in an associated asset record to use as the start date of the warranty's coverage of that asset. For example, if the Start Date Type of the warranty is Installed Date, then the Installed Date of the asset is used as the start date of the warranty associated with that asset. |
Duration (Days) |
Specifies the length of the covered period under the warranty. |
Measurement Type |
Specifies the type of measurement used to determine if the usage limitation of a concurrent warranty is exceeded or not. |
Unit of Measure |
Specifies the unit of measure for measuring usage of the asset under warranty. |
Usage Amount |
The limitation on usage of the asset under warranty, above which the warranty is no longer valid. |
Transferable |
When checked, the warranty is transferred from an uninstalled asset to an installed asset upon recording an asset swap. For more information, see Asset Swaps. |
Transportation |
Indicates that this warranty covers the cost of transportation. |
