Siebel Forecasting Guide > Forecasting Requirements > About Using the Periods Table in ForecastingThe Periods table includes buckets of time such as weeks, months, quarters, and years. While some organizations use standard calendar reporting periods, other organizations use fiscal reporting periods. Siebel eBusiness Applications provide flexibility in this area, so organizations can set up periods that make sense for them. Because forecasting often goes months or years into the future, it is important to establish periods not just for the current month or quarter, but for several quarters or years in advance. Ideally, enough periods should be created to allow at least a few months of forecasting without having to go back into the Periods table every time someone needs to forecast. Generally, periods should be contiguous (one period ends on January 31st and the next period begins on February 1st), and regular (periods are whole calendar months or always go from the 15th of one month to the 14th of the next month). Typically, the smaller buckets, such as months, fit into the larger buckets, such as quarters. The beginning of a month often coincides with the beginning of a quarter, or the end of a month coincides with the end of a quarter. Table 3 illustrates how the periods defined for forecasting might look. While there are many other ways to establish periods in Siebel applications, contiguous, regular small periods, which fit nicely into the larger periods, are recommended. For information on how to set up periods, see the chapter that discusses ongoing administrative tasks in Applications Administration Guide. |
| Siebel Forecasting Guide |
