Siebel Forecasting Guide > Setting Up Forecasting > Adding Forecast Series OrganizationsThe Forecast Series Organizations view lists the organizations who will participate in the forecast series. It is useful when you are creating a forecast for a large set of participants. Like the Forecast Series Participants view, the organization determines whether an employee can create a forecast within a given series. To add an organization to a series
NOTE: Organization-defined forecasts do not use auto-forecast as this could cause confusion in very large organizations. Because auto-forecast is not enabled for organization-defined forecasts, make sure that your forecast series process allows that end users create their own forecasts or that managers create and add absentee forecasts when appropriate. |
| Siebel Forecasting Guide |
