Siebel Forecasting Guide > Common High-Level Forecast Usage Scenarios > Opportunity Product ForecastingA company needs to forecast both opportunity and product revenues related to opportunities, but only wants to see forecast details by opportunity. Administrator Usage ScenarioThe administrator defines an opportunity product forecast series. The Auto Forecast Search Spec is set as follows: [Product] IS NOT NULL and [Calculated Primary Flag] = 'N'. This search pulls product revenue line items that have a product indicated into the forecast. End User Revenue Scenario
End User Forecast Scenario
NOTE: To rollup total quantity, the administrator needs to expose the quantity rollup in the total forecast. This is a simple configuration procedure. Also to use the forecast queries to filter opportunities, the administrator needs to configure this. About Forecasting Opportunity ProductsThe Expected Delivery Date field in the Opportunities screen > Products view determines the column (month) into which that product falls in the forecasting views. For example, several opportunity products can be combined into one product forecast record. The value that is seen for January for product x might be an aggregation of several opportunity product records. If the date on one of those records is changed, thereby knocking it out of the forecast, other records might still remain with slightly lower quantities or a slightly different average price. |
| Siebel Forecasting Guide |
