Table 12. Forecast 2000 - Forecast Item Detail Flat
Adjustment: Adjustable |
Y |
Used internally. See Forecast Item: Adjustable in Table 10. |
Adjustment: Adjustable Field (N) |
<Forecast Item Detail Flat field> |
See Forecast Item: Adjustable Field (N) in Table 10. |
Adjustment: Adjustment Allowed Field Name |
Adjustment Allowed |
Used internally. See Forecast Item: Adjustment Allowed Field Name in Table 10. |
Adjustment: Adjustment Context BC Name |
Forecast 2000 - Forecast |
Used internally. See Forecast Item: Adjustment Context BC Name in Table 10. |
Adjustment: Adjustment Context Id Field Name |
Owner Forecast Id |
Used internally. See Forecast Item: Adjustment Context Id Field Name in Table 10. |
Adjustment: Adjustment Flag Field Name |
Adjusted Flag |
Used internally. See Forecast Item: Adjustment Flag Field Name in Table 10. |
Adjustment: Adjustment For Id Field Name |
Adjustment For Id |
Used internally. See Forecast Item: Adjustment For Id Field Name in Table 10. |
Adjustment: Context BC Position Id Field Name |
Owner Position Id |
Used internally. See Forecast Item: Context BC Position Id Field Name in Table 10. |
Adjustment: Owner Position Id Field Name |
Owner Position Id |
Used internally. See Forecast Item: Owner Position Id in Table 10. |
Adjustment: Force Unadjust Parent BC |
Forecast 2000 - Forecast Item |
Used internally. When unadjusting this business component, the parent business component may also need to be unadjusted, for example, if it drives the visibility of this business component. |
Adjustment: Force Unadjust Parent BC Id Field Name |
Forecast Item Id |
Used internally. When unadjusting this business component, the field on this business component which links to the parent business component that it should unadjust. |
Revenue Associate List |
Y |
See Forecast Item: Revenue Associate List in Table 10. |
Revenue Field Map: <Forecast Item Detail Field> |
<Revenue Field> |
See Forecast Item: Revenue Field Map in Table 10. |
