Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Fundamentals > About the User Interface > About the Application-Level MenuThe application-level menu is located in the upper left corner of the application window. The functionality provided by each menu in the application-level menu depends on the application and the configuration you are using. Each menu option lets you perform a task. Look for topics in this document that explain the task you want to perform to find out how you can use a menu and its options. |
Fundamentals |
