Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Fundamentals > Common Record Tasks > Adding Notes to RecordsWhen you are working with records, you will often find that you need to make notes. You can add a note to a record in the Notes view. In the Notes view, you can enter public notes or private notes. Use the link bar in the Notes view to switch between public and private notes. A public note can be seen by anyone who has access to the record. A private note can be seen only by the person who enters the note. The Notes view is not available in all screens. It appears only where it would be logical to keep notes for individual records, for instance in the Accounts, Contacts, and Opportunities screens.
Related Topic |
Fundamentals |
