Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Fundamentals > Common Record Tasks > Copying RecordsIf a significant amount of data in a new record you want to add is similar to the data in an existing record, it may be more efficient to copy the existing record and then modify the copy. |
Fundamentals |
