Fundamentals > Common Record Tasks > Canceling ChangesYou may find that you need to cancel edits you have made to a record before you save it. You can undo your edits to a record only if you have not saved it yet. To cancel edits in form or a list NOTE: You cannot undo changes or additions made to selection dialog boxes. For example, when you add or remove employees from a selection dialog box. |
| Fundamentals |
