Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Changing the Length of the Calendar Day
The Daily view in your calendar shows your default work day, but it may not reflect the hours you are actually at work. You can change the length of the calendar day from the User Preferences screen. To change the length of the calendar day
- From the application-level menu, choose Tools > User Preferences.
The User Preferences screen appears.
- On the link bar, click Calendar.
The Calendar form appears.
- Enter the desired calendar start time in the Working Hours Start At field.
- Enter the desired calendar end time in the Working Hours End At field.
