Fundamentals > Setting User Preferences > Customizing Aspects of the Calendar >
Setting Up Default Calendar Views
You can set up a default calendar view to appear every time you access the Calendar screen. For example, if you use the monthly calendar all the time, it will be helpful for you to have the monthly calendar set up as the default calendar view. To set up a default calendar view
- From the application-level menu, choose Tools > User Preferences.
The User Preferences screen appears.
- On the link bar, click Calendar.
The Calendar form appears.
- From the Default Calendar drop-down list, choose Daily, Weekly, or Monthly.
- If you selected Weekly as the Default Calendar, choose 5 Day Weekly or 7 Day Weekly from the Weekly Calendar View drop-down list to define the default weekly calendar view.
