Fundamentals > Using the Calendar >
Deleting Calendar Activities
You can delete an activity from the calendar in any view of the Calendar screen. To delete an activity
- Navigate to the Calendar screen.
- In the Daily, Weekly, or Monthly view, click the Description hyperlink to access the activity.
The Calendar Detail form appears.
- Click Delete This One.
If you are the primary employee for the activity, the activity is deleted from every participant's calendar. If you are a non primary employee for the activity, the activity is deleted only from your calendar.
