Fundamentals > Using the Calendar > Changing the DateYou can change the date or time zone in any of the Calendar views. This is helpful if you frequently travel in a number of time zones. You can change the date in any of the Calendar views.
NOTE: You can set a default time zone for your calendar in the User Preferences screen. For more information, see Setting Time Zone Preferences. |
Fundamentals |
