Fundamentals > Using Query to Locate Information >
About Querying
Querying is a way to locate one or more records that meet your criteria. The subset of records found by a query can be viewed on-screen, exported to a file, or used as input for a report. A query searches the database for a specific subset of data based on one or more conditions or criteria. For example, you may need to find all open service requests with a high priority. This query is performed in the Service screen with the query criteria of Status = Open and Priority = High. When you create a query, you can save and reuse the criteria.
