Fundamentals > Using Query to Locate Information >
Creating, Executing, and Saving Queries
You can create your own queries and save them in the Queries drop-down list for later use. Queries that you create are called user-defined queries. They allow you to enter your own criteria to locate a specific set of records. To create, execute, and save a new query
- Navigate to the desired screen.
- Do one of the following:
- Enter the query criteria in the appropriate fields.
- From the application-level menu, choose Query > Save Query As.
The Save Query As dialog box appears.
- In the Query Name field, enter a name for the query and click OK.
The saved query now appears in the Queries drop-down list.
