Fundamentals > Using Query to Locate Information >
Canceling Long-Running Queries
Depending on how your Siebel application has been set up, you may be able to cancel queries that run for a long time. For more information about your setup, contact your Siebel administrator. To cancel a long-running query
- Execute a query.
If the query does not return records after a specified period of time, a dialog box appears.
- Click Cancel.
A confirmation dialog box appears to confirm that the query canceled successfully.
- Click OK.
