Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Tax Code Administration >
Creating a Tax Code
Use the following procedure to create tax codes. This task is a step in Tax Code Administration. To create a tax code
- Navigate to the Tax Service Admin screen > Tax List view.
- In the Taxes list, create a new record, and complete the fields.
Some of the fields are described in the following table.
NOTE: You can enter data in either the Amount or Percent field, but not both.
Name |
The name of the tax. |
Percent |
The tax defined as a percentage. The amount of tax charged is the percent value multiplied by the price for the line item. |
Amount |
Tax defined as a flat fee. The flat fee is a preset amount. |
Start Date |
The date the tax becomes active. |
End Date |
The date the tax becomes inactive. |
Currency |
The currency of the tax. Defaults to the default currency of the application. |
City |
City in which the tax applies. It may apply in many different cities depending on the properties associated with the tax. |
State |
State in which the tax applies. This field is automatically populated when the City field is completed. |
