Siebel Hospitality Guide > Working with Inventory > Actualizing a FunctionThe Actualization process is performed on Function and Room Block records. The process of setting a sales status to Actual occurs after the function is completed or the room block has been used. At that point, the revenue becomes actualized. See Table 21 for a description of the Actual status. Actualized revenue is the total revenue generated from all sales (transient room, group room, catering, and so on). When the term is applied to sleeping rooms, it refers to the number of sleeping rooms on the property that were actually used. Actual status can also be applied to food and beverage covers and event attendees. When the function and room block records are actualized, the following actions occur:
This task is a step in Process of Working with Event Inventory.
| Siebel Hospitality Guide |
