Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up Volume Discounts >
Creating Volume Discounts
Volume discounts are created through the Administration - Pricing screen. For more detailed information about how to create a volume discount, see Pricing Administration Guide. This task is a step in Setting Up Volume Discounts. To create a volume discount record
- Navigate to the Administration - Pricing screen > Volume Discounts list.
- In the My Volume Discounts list, create a new record, complete the fields and save the record.
Some of the fields are described in the following table.
Name |
Enter a name for this volume discount. |
Discount Method |
Select the discount method from the picklist. The options are Simple and Tiered. For more detailed information about these methods, see Pricing Administration Guide. |
Effective From |
The date from which this volume discount will become effective. |
Effective To |
The date on which this volume discount will become ineffective. If the volume discount will not expire, leave this field blank. |
Exchange Date |
If you are converting currencies, enter the date for the currency exchange rate. The system will use the exchange rate on that date to convert currency. |
Description |
Enter a description of the purpose of the volume discount. |
