Name |
Enter a name for the discount at this property. |
Description |
Enter a description of the discount. |
Volume Discount |
Select the discount to be associated with this property. |
Start Date |
The date from which the volume discount will become effective. |
Start Day |
This field is automatically populated after the Start Date field is completed. |
End Date |
The date after which the volume discount is no longer effective. |
End Day |
This field is automatically populated after the End Date field is completed. |
Product |
Select a product to which the volume discount applies. |
Product Line |
Select a product line to which the volume discount applies. Select either a product or product line. NOTE: You can only specify either Product or Product Line for any Volume Discount.
Created By |
The User Id of the user who created the Volume discount. |
Created Date |
The date on which the volume discount was created. |
