Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > About the Property Pricing Profile > Defining Weekend PricesThe property administrator can specify which days are considered to be weekdays and which are weekends for each day of the week. For example, the administrator can define Friday as a weekend day, define Saturday as a weekday, and then set Sunday as a weekend day. To define weekends and weekdays, you must select the Weekend/Weekday check box flag in the Property record. This task is a step in Process of Setting Up Pricing and Property Pricing. To define weekday and weekend days
NOTE: If you select the Weekday-Weekend check box on the property record, the weekend will be defined as Saturday and Sunday by default. |
| Siebel Hospitality Guide |
