Siebel Hospitality Guide > Working with Quote and Order Pricing > Sleeping Room Pricing > Minimum and Maximum PriceThe user can define the minimum and maximum price for each room type. If minimum and maximum prices are not defined, then the minimum and maximum prices are null as opposed to zero. Setting minimum and maximum prices makes sure pricing does not go below or above the set prices after all pricing rules are applied. |
| Siebel Hospitality Guide |
