Siebel Hospitality Guide > Managing Recurring Events > Creating the Recurring OpportunityThe recurring event is created in the Opportunities List in the same manner as other opportunities. This task is a step in Creating Recurring Events.
NOTE: When you create a recurring opportunity, you cannot select a Property, create a function agenda or create a room block for the opportunity. However, you can do this for the opportunity's subopportunities. Also, it is not possible to generate a quote for the opportunity. Instead, quotes must be generated for its subopportunities. |
| Siebel Hospitality Guide |
