Siebel Hospitality Guide > Creating Hospitality Reports > About the Quote Summary Report >
Generating and Printing the Quote Summary Report
Perform the steps in the following procedure to generate and print a Quote Summary report. This task is a step in Process of Generating Hospitality Reports. To generate and print a Quote Summary report
- Navigate to the Quotes screen > Quotes list view.
- In the Quotes list, query for the quote.
- In the Quote record, click the link in the Quote Name field.
- Click the Summary view tab.
- From the toolbar, click the Reports button.
- In the Select a Report menu, click Quote Summary Report.
The Quote Summary report is generated in a Siebel Report Viewer window.
- Click the Print Setup button to display a standard Windows print dialog box.
- Choose appropriate printer settings, and then click OK.
Related Topic
