Siebel Hospitality Guide > Creating Hospitality Reports > About the Function Space Products Report >
Generating and Printing a Function Space Products Report
Perform the steps in the following procedure to generate and print a Function Space Products report. This task is a step in Process of Generating Hospitality Reports. To generate and print a Function Space Products report
- Navigate to the Property Administration screen > Category view.
- From the toolbar, click the Reports button.
- In the Select a Report menu, click Function Space Products Report.
- In the dialog box that appears, enter the name of the property for which you want the report, and then click Finish.
The Function Space Products report is generated in a Siebel Report Viewer window.
- Scroll through the pages to view the details for each category and its specific spaces.
- Click the Print Setup button to display a standard Windows print dialog box.
- Choose appropriate printer settings, and then click OK.
