Siebel Hospitality Guide > Creating Hospitality Reports > About the FSI New Bookings Report >
Generating and Printing an FSI New Bookings Report
Perform the steps in the following procedure to generate and print an FSI New Bookings report. This task is a step in Process of Generating Hospitality Reports. To generate and print an FSI New Bookings report
- Navigate to the Quotes screen > List view.
- Query for a quote and drill down on the value in the Name field.
- Scroll down from the Functions list and click the Function Space view tab.
- From the toolbar, click the Reports button.
- In the Select a Report menu, click FSI New Bookings Report.
The following table describes some of the fields in the New Booking Report Parameters dialog box.
New Bookings |
When it is selected, this check box indicates that a New Bookings report is generated. |
Status Change |
When it is selected, this check box to generate a Status Change report. |
Date |
The date on which the quote was created. |
Arrival Date |
The arrival date entered for the quotes. |
FS Availability |
Function space availability—select one of the options from Total, Partial, or None. |
SR Availability |
Sleeping room availability—select one of the options from Total, Partial, or None. |
Sales Manager |
The sales manager with whom the quote should be associated. |
Event Manager |
The event manager with whom the quote should be associated. |
Property |
The name of the property for which the report is being generated. |
Business Type |
The type of business opportunity. |
Status |
The status of the quote. |
Status Changed By |
Employee login to identify the person who changed the quote. |
CRS Code |
The Central Reservations Code for the property. Enter this or the property name to specify a property for the report. |
Sort by 1 |
The first parameter that users can enter to sort the report results. |
Sort by 2 |
The second parameter that users can enter to sort the report results. |
Sort by 3 |
The third parameter that users can enter to sort the report results. |
- In the New Booking Report Parameters dialog box, perform the following steps:
- Select either or both of the New Bookings and Status Change check boxes.
- Choose some parameters from the Report, Availability, Manager, and Quote Parameters sections to filter the information as you require.
- In the Sort Parameters section, select a maximum of three parameters that will be used to sort the report results.
- Click Finish.
The FSI New Bookings report is generated in a Siebel Report Viewer window.
- Click the Print Setup button to display a standard Windows print dialog box.
- Choose appropriate printer settings, and then click OK.
