Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Schema on the DB2 Host > Process of Performing a Custom Installation > About Reviewing the Log Files for UNIXThe Siebel Database Server installation and configuration creates a number of log files, such as srvrupgwiz.log and srvrupgwiz1.log (which increments to additional logs) within the When you install your base language pack, it creates a special log file, dataimp_prim_lang.log. The main log file produced by the Siebel Upgrade Wizard (Srvrupgwiz.log), does not contain errors returned by applications. Additional information about the configuration process can be found in the sw_cfg_util.log file. Depending on the operation performed, the ddl_ctl.log file reflects any errors. To find additional operation-specific log files, open Srvrupgwiz.log, using any text editor, and search for a ".log" string. This shows the names of the log files produced during the operation. For example, if the configuration of the Database Server fails, the Srvrupgwiz.log contains the following information: GenericLog GenericError 1 2002-02-28 15:51:24 (err=1) was returned by application (/sea78/siebsrvr/bin/ddlimp.exe ...) GenericLog GenericError 1 2002-02-28 15:51:24 Execute file action failed (err=Launching the application) In the previous example, the ddlimp.log file contains a detailed error message, such as the following: DDLIMP-ERR-1071: Unable to build ddl statement "add col" (Open unloadtbl.jcl) For further information on reviewing Siebel Schema installation and configuration error messages, see Acceptable Errors and the errors.rtf File. |
| Implementing Siebel Business Applications on DB2 UDB for z/OS |
